Winterizing a Volvo drive
I winterized a boat with a SBC and a Volvo drive today. Drained the block, both ex. manifolds, ray water pump and refilled the motor/exhaust with RV antifreeze. Is there anything that I should have done to the drive?
Gary |
i run a 290aq all i do is pull the prop and put some anti seize on the shaft, put the drive all the way down and leave it down and any left over water will drain out ,and spray it will wd 40, then spring chgange the fluid.
You are supposed to change the oil in case any water is in there wont sit in there or freeze over the winter.
I've been known to forget this every other year.....lol |
fixx
drain the block again and get rid of the rv antifreeze..it will start to slush @ 17* then freeze @ zero *
+1 for draining the lower unit.. |
We used Polar RV antifreeze that states on the label that it is for RV, marine and home use and is propylene glycol based that protects to -50 degrees F. Any comments when used in a non-diluted application?
fixx
Originally Posted by RMPRam
(Post 3534514)
Originally Posted by innerrage
(Post 3533627)
Originally Posted by Too Stroked
(Post 3534669)
If that's all you're doing to winterize it, you must live in an area that never sees temperatures below freezing. Your block, exhaust manifolds, and raw water pump are still full of water.
(Post 3534759)
I believe that he is answering my question as to how to winterize the Volvo outdrive and not addressing a general engine winterize.
i live in ct and i pull all my exchaust plugs and block and impropeller plate off and let it drain out,and spray silicone over the motor,pull the to batterys and carb off and drain out the fuel,boat stays in a semi heated garage year round.
| All times are GMT -5. The time now is 04:43 PM. |
