Tow vehecle
WIll a 4 door Chev 1/2ton 4x4 pull a 35ft boat OK? Like the 33 oultalw or a 353 fastech? Will be towing up to a max of 100 miles at certain times of the summer to go boating? Air bags be enough to assist?
It will do it, short distances but I think you might be over your weight limit with the boat wet and trailer weight added. If you do use it, def do the air bags and depending on your engine, pray for shallow ramp angles and no-one cutting you off
I wouldn't brakes suck in half tons, may take off ok but stopping or correcting a sway will be tough
Nope. A half ton won't cut it. Baja's and Formula's are not light.
You`re nuts!
My 33 loaded with trailer is 12k#. I had a 1/2 ton truck for my 25' A.T. I would **** my pants if I had to use it on the 33. Time for a new 'vehecle':drink: |
Originally Posted by kragar
(Post 3541327)
My 25 OL wasn't noticable on the back of the truck. Boat is gone and now deciding on next boat. Not crazy about buying a truck as well. I see all kinds of 30 Outlaws being towed by regular cab trucks and toyotas.
Just cuz it's done doesn't mean it works well. it's not your driving ability it's the azzhat that cuts you off
Short distance only. Small brakes on that truck also. Make sure the new trailer has disc brakes and would suggest electric over hydrolic brakes on trailer.
In a word: hellfrickinno
