-   -   What is Causing This? (https://www.offshoreonly.com/forums/general-q/265360-what-causing.html)
TW720HVY 11-07-2011 01:16 PM
3 Attachment(s)
I just put her to bed yesterday and came across this. It only has about 5 or 6 hours on it since the re-build. It is a 496 with Dart heads and CMI sport tubes.
Is there more to this rust than just rust or is it nothing to worry about?
Thanks for the help.
Knot 4 Me 11-07-2011 01:35 PM
Looks to me like heat has just burned the paint away and then normal condensation has caused some minor surface rust.
mike tkach 11-07-2011 02:03 PM
might be some water running up the head bolt,i dont know what block you are useing,but if the headbolt holes are not blind holes,you need a lot of sealer on the threads or that will happen,pull that headbolt ,clean it,and apply locktite PIPE THREAD SEALEMT.
TW720HVY 11-07-2011 03:29 PM
Thanks for the replies. I did not know if I was over thinking this.
mike tkach, it is the stock 496 block.
Jeff P31 11-07-2011 05:06 PM
If it is closed cooling it would be antifreeze leaking around the head bolt not water. You could pressure check the cooling system but if it is not low I would not worry about leaking head bolts .
TW720HVY 11-08-2011 09:44 AM
It is a closed cooling system.
Can reversion cause this?
Knot 4 Me 11-08-2011 10:39 AM
You would have an exhaust leak then that would be quite noticeable.
TW720HVY 11-08-2011 06:41 PM
Thank you everyone for the help!
