merc t-bolt IV wiring
OK techies, i need i alittle help with wiring a merc T-bolt IV ignition into my boat. right now it has the stock volvo/mallory points type distributor. i took the merc setup off a 260 and it is complete, box/dist/coil. heres what i got
black wire from body of distributer - ? wires coming from box white with red stripe - to white/red terminal on dist. white with green stripe - to white/green terminal on dist. purple wire - ? grey - ? pos on coil - ? neg on coil - ? i also have a mallory promaster coil i was think'n of using, what are your thought on using it with this system. oh yea and do i get rid of that ballast resistor thing that was in the old ignition? any help would be great. thanks all :cool: :cool: |
Re: merc t-bolt IV wiring
Originally posted by glassdave OK techies, i need i alittle help with wiring a merc T-bolt IV ignition into my boat. right now it has the stock volvo/mallory points type distributor. i took the merc setup off a 260 and it is complete, box/dist/coil. heres what i got black wire from body of distributer - ? <Ground> wires coming from box white with red stripe - to white/red terminal on dist. <yep> white with green stripe - to white/green terminal on dist. <again, yep> purple wire - ? < pos side of coil> grey - ? <neg side of coil> pos on coil - ? <purple> neg on coil - ? < grey> i oh yea and do i get rid of that ballast resistor thing that was in the old ignition? any help would be great. thanks all :cool: :cool: Jerry |
thanks jerry. one other quick question. does the keyed ignition power (+) just go the pos on the coil than? :cool: :cool: thanks again for the help. any thoughts on the promaster coil?
Yes,
2 purple wires to pos side of coil. 1 from ignition module, other from ignition switch itself. If you have an oil pressure switch wired to an electric choke, that also will have a purple wire going to coil. Should also have 2 grey wires to coil neg side. 1 from ign. module, other from tach. No experience with that coil. I have an MSD high vibration coil that I installed this spring. No difference from the stock Merc coil as far as I can tell. Jerry |
thanks US1 Fountain, YOU DA MAN.:cool: :cool: :cool:
| All times are GMT -5. The time now is 04:43 PM. |
