Blower help BM250 Belt issue!
I have an alignment issue with the 16 rib belt on a BM 250. The driven and tension line up perfect but the crank alignment is off .300. The pulley is too close to the block. Is there a spacer that small I am missing?
Any tech manuals would be helpful! Lower pulley#891330 Thanks |
Mine had a spacer between the pulleys
Are you using the proper V-belt pulley? There should be a spacer behind the Drive pulley.
Had the same issue on a weiand, the issue is merc made a few diff lower pulleys and they are all different....had to have a spacer made to get mine right..
Got it figured out. I need a 1/4 inch spacer and then add a pin to the works of it for centering. Thanks guys!
| All times are GMT -5. The time now is 11:05 PM. |
