Subwoofer Location - Advice Needed
I'm looking to put two 10" free air subwoofers into my 28' Bertram Baron project http://www.offshoreonly.com/forums/c...8-project.html . My thought was to mount them under the rear bench on either side in the gunnels. I really want to try to hide them so they will not be seen from inside the cockpit that way I can try to keep the classic look of the interior. They would be mounted so the subs face each other toward the center of the boat. The inside volume of the underseat compartment is about 9.5 cubic feet but I'm sure it will be used for storage as well. From what I've read it sounds like free air / infinite baffle subs must be mounted so the fronts and backs are not in the same air space. My concern is this an acceptable location for them and the amount of sound I would get from this setup compared to the subs facing the cockpit. I will also have four 7" speakers inside the gunnels facing inward. I will be using a 5 channel amp with 75w to each speaker and 300w to the subs. I'm thinking of using Alpine components just to stay within my budget. It's a small cockpit at 5' x 7' so I'm hoping to get some decent sound but nothing to radical. Any help or advice would be appreciated.
I think they will be ok where you have them drawn. Maybe not the best because some of the bass will get muffled. On the other hand it may push the bass throughout the boat more.
what is that rectangular hole on the left side of the picture near the bottom? it looks like there is one on each side, if you can install a false speaker grill there, you can face the woofer of each sub outwards and that space will act as a port for each sub, should give decent bass that way.
