Subwoofer basics
I'm kinda confused. I pulled the 10" sealed Jl sub out of my truck and installed it in the cabin of my 25zx...same amp. It sounds nothing like it does in my truck...no where near as loud. I tried facing it a in several different directions. Whats the deal here?
I was planning on dropping some coin on a complete JL system with 10"IB subs. Am I going to be dissapointed? how do I get a marine system to sound like the system in my truck...do I have to build a ported enclosure??? |
A truck is small enclosed area. Boat stereos take a lot more power and speakers to achieve the same results.
Yes I am sure you will be disappointed. It is very hard to get a lot of bass out of a boat. I am pushing 4-12's and a 18" and its loud, but 1/2 of what it would be in a car. Like Griff said, it will also take a crap ton of power to push your amps. It will take double that to make it loud enough to make a noticeable difference outside your boat. Plan on spending some serious dollars.
Open air sterio in a boat is just like the motor. You need alot more than you originally thought and when you get done and are pleased with the setup, someone else runs by you and your mouth hits the floor. JL makes great stuff you just need more of it :musik010:
use a ported enclosure & not infinite baffle
how about this?...Clearly its not marine rated, but.....
http://www.ebay.com/itm/CP112W0v2-JL...item1e64698d66 |
Originally Posted by tnc110
(Post 3549906)
I was planning on dropping some coin on a complete JL system with 10"IB subs. Am I going to be dissapointed? how do I get a marine system to sound like the system in my truck...do I have to build a ported enclosure??? If it is in an enclosure now it should sound pretty good in the cabin as that is enclosed. Did you try playing with any adjustments on your head unit? I know mine has a level adjustment for the preamp outputs that make a HUGE difference. Just a thought. |
My head unit also has a control for the sub output. That could be an issue.
When mine was set to the neutral position, the subs were very weak. When I turned it up, it made a HUGE difference. |
I used a 10" bazooka sub with 500 watt dedicated amp, Subs really need to be inside specific designed boxes for best effect. Mine will THUMP when I want it to. But my THUMP may be peanuts to what you want. The chairman (Sinatra) doesn't need much thump to sound good.
I put the bazooka under the rear bench, that also has two 6X10's with an amp for them, 6" rounds in the cabin driven by the receiver amp. I think my system sounds fine and that is all that matters. When the sub fires (pointed to the exterior hull of the boat) it vibrates the hull pretty good. |
Clarion m309 hu...not too happy w it...just replaced a dual with it. The dual sounded much better. I have turned up the sub output... Emailed jl audio for advise
