Any one using this cam??
I am looking to upgrade to a retro fit roller cam from my current setup. I found this "kit" on Keith Eickerts web site. Seems like a good up grade from what I have now. Any thoughts?
http://www.keitheickert.com/p-15796-...ifter-kit.aspx It will be going in a 509ci bbc with open chamber rectangle port heads 118cc, sinlge plane hp 500 maninfold and 850cfm carb, with emi thunder exhaust. current cam is a hydrualic flat tappet compcams 280AH with a duration of 232/237 @ .50 and .547 lift across the board. |
Call mark at bullet cams
| All times are GMT -5. The time now is 03:06 PM. |
