-   -   Garage Size? (https://www.offshoreonly.com/forums/general-q/266325-garage-size.html)
OhioRiverCigarett 11-27-2011 07:26 PM
Garage Size?
My wife and I are building our dream house and I have a bay dedicated for my 81 33' Cigarette. My question is what is a reasonable size garage. I am a self-servicing boater. I have had my engines out multiple times but always performed the work outside. What is concerning me is the "right" size garage, to be able to walk engine stands around the boat with good clearances. Any thoughts? Thanks for the help
Tinkerer 11-27-2011 07:32 PM
The boat side of my barn is 15 x 41 inside dimensions.
plenty of room to do any repairs needed.
I installed in floor heat also. VERY comfortable and cheap to run. I keep my barn at 50* all winter and 68* and 50% humidity all summer.
Can I say I love it.
502ss 11-27-2011 07:49 PM
In the early stages of building an addition on my existing garage to hold my 30' scarab. I like you do all my work myself and up until now have always had to work on this boat out side unless I have engine work in which case I have to pull the engines and work on them in the winter.
With drives and trailer tongue I am looking at 38'. I am building a 16' x 45' addition at the rear of my garage. I would like to go bigger but as you can see from the design layouts it needs to stay the same width as the existing building.
If I was you I would go with a 25'x55 building. You did say it was your dream house so why not be the dream garage too :)
Make sure to post some pics!
http://i69.photobucket.com/albums/i4...ss/garage2.jpg
http://i69.photobucket.com/albums/i4...ss/garage1.jpg
http://i69.photobucket.com/albums/i4...ss/garage3.jpg
OhioRiverCigarett 11-27-2011 08:01 PM
sizes
Probably shouldn't of mention dream house. We currently have a 20x 50 bay in the design, but I was considering shrinking it to 18 (0r 16) x 45. Trying to control costs.
verbi69 11-27-2011 08:14 PM
I think it would be wise to go as big as you can go for new construction.....paint the floors in the house to keep costs down, don't sacrifice on garage floor space....just my two cents.
502ss 11-27-2011 08:19 PM
Understood!
Well the 33 plus the trailer with drives is probably pushing 40' so that only leaves you 10' at the back of the boat. I think 20' wide should work. Not sure I would make it any smaller unless you have other bays to do all your work in?
blownhammer2000 11-27-2011 08:25 PM
+1, build the biggest you can for the allowance you have, i work in the building industry and had this same issue when we built our house 3 yrs ago, wanted a big garage but living in a neighborhood the land just wasn't there, so we bought a corner lot w walkout basement and i put another driveway on the side w a 12x8 door going in the basement and took the entire basement, 45x60, as my man cave, and love every sec of it
RunninHotRacing163.1 11-27-2011 08:27 PM
160 ' X 60' should do ya even room for the wifes car :drink::drink:
ROCK ON !!!!!!!!!!!!!!!!!!!!!:coolcowboy:
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:drink:
Tinkerer 11-27-2011 09:05 PM
If I could rebuild my garage I would have made it 5' deeper but the boat side at 15' is wide enough. The work shop side is 20' wide. I would have made it 5' wider if I could do it again. Because I have the work shop side I don't need more than 15' wide on the boat side.
tnc110 11-27-2011 09:11 PM
Might consider a detach...that way you wont piss off the wife every time you fire up whatever toy you are working on in the garage.
Tinkerer 11-27-2011 09:19 PM
http://i867.photobucket.com/albums/a...itbeck/048.jpg
Tinkerer 11-27-2011 09:20 PM
http://i867.photobucket.com/albums/a...itbeck/047.jpg
Tinkerer 11-27-2011 09:22 PM
http://http://i867.photobucket.com/albums/a...15-2011028.jpg
Tinkerer 11-27-2011 09:25 PM
Back wall is 6' tall concrete wall holding back 5 1/2 feet of earth. RH side has a 14' tall ceiling, LH side has an 11' ceiling.
ArchieDrew 11-27-2011 11:39 PM
I just built a 12'x12' shed with a 9'x7' garage door. I vinyl sided it, roofed it, and added vented soffit for air circulation and attached it to a cement pad with a built in ramp for around 2 grand. When I put the bike on its jack I can spin the bike around facing the door and ride right out. I also have plenty of room for a lot more bike things in there.
502ss 11-28-2011 07:57 AM
How many boats can you fit in it? :lolhit::evilb:
J/K :drink:
mr3dman 11-28-2011 08:01 AM
J/K :drink:
He has a Aronow designed paddle boat in there, a true classic:drink:
zt260 11-28-2011 10:14 AM
I have a 5 car garage and I’m building another one.
I have a buddy that put up a two level garage. 110’ X 50’
He still filled it…
Bottom Line-
You can’t build it big enough. Build as much as you can borrow and then some.:drink:
ICDEDPPL 11-28-2011 10:57 AM
Originally Posted by zt260 (Post 3558912)
Bottom Line-
:stupid:
This way you don`t have this problem 2 years later after adding an addition. Who knew I was going to have 8' itis thou :picard1:
old boat fit nice
http://img.photobucket.com/albums/v4...t/6eaebc35.jpg
new one not so much..my garage has a condom now:
http://img.photobucket.com/albums/v4...n/22e96851.jpg
http://img.photobucket.com/albums/v4...r/6eb11765.jpg
I should have built it bigger
http://img.photobucket.com/albums/v4...r/7446674d.jpg
Sydwayz 11-28-2011 12:09 PM
Go HUGE!! You will fill it up. I guarantee it.
I've got a 30x60 pole barn with 12 feet ceiling height.
Search for Active Thunder Toy Box here on OSO.
502ss 11-28-2011 02:50 PM
I will save Everyone the trouble!
http://www.offshoreonly.com/forums/a...-box-up-2.html
Boy am I jealous!! :traurig001:
502ss 11-28-2011 02:53 PM
Originally Posted by ICDEDPPL (Post 3558934)
:stupid:
At least it kinda fits!
Mine won't get past the windshield! :angry-smiley-038:
http://i69.photobucket.com/albums/i4...b/7f1aeea1.jpg
BenPerfected 11-28-2011 03:11 PM
You can debate the W X L forever. If you are going to pull the engines from a hoist, you need a min of 14' clear height.
thescooter 11-28-2011 03:18 PM
from my experience.
go as big as you can, but only what you can afford.
you end needing alot of space.
for other things! in the future
sports cars motorcycles go karts etc
bigger is better.
best of luck n have fun or do not do it
blownhammer2000 11-28-2011 07:58 PM
i don't care who you are thats funny right there!
tcelano 11-28-2011 10:30 PM
Yes, or more. My gantry that I built rolls in just under my 14' door, and it just barely was able to clear a supercharged motor over the transom of my Mistress, with the hatch off, which is a fairly shallow hull. If you are working on deeper boat with blower motors, and you want to pull them complete, go 15' overhead at least, and pay attention to where you put light fixtures.
tcelano 11-28-2011 10:35 PM
P.S. that's using a 6" I-beam a roller trolley and a 3-Ton chainhoist. You can probably shave a bit of headroom from what I have.
The real ticket is if you could integrate an x-y gantry crane into the structure of your shop during construction.
Griff 11-29-2011 01:54 AM
I would definately leave it where you have it. It has a lot of extra room now, but might not 8 years down the road.
If I move up in boat size now, it would cost me probably 8-10k to make my garage 8-10' longer. Its 40' deep now. It would have cost me about 3k to do it when I originally had the house built. I kick myself all the time for not doing it then.
