drive &tab pump oil
Hi all can anyone tell me the correct oil to put in the trim and tab pumps , the tab pump has kiekhaefer wrote on it and says 10/30 or 10/40 is this just motor oil ?? the drive pump oil looks thinner but it does not say on the pump wot to put in it . thanks for any help . paul
Mercury/Quicksilver power trim and steering fluid #1
or you can use a 30 weight oil that makes you happy. The Merc stuff has anti foaming agents in it and is non detergent. |
i have always used 10/30 never had any issues with it.
Originally Posted by pstorti
(Post 3567492)
(Post 3567492)
Thanks guys , i did take the time to read up in my SELOC repair manual befor i posted , but it contradicts itself, in one section it says you can use 10/30 oil in a emergency , but drain as soon as poss , then in the maintenance section , it says you can use 10/30 oil and nothing about draining it out?? so i thought i would see wot you guys are putting in the pumps . Its unanimous 10/30 thanks .
I run tranny fluid.
Originally Posted by kvogt
(Post 3568324)
I run tranny fluid.
Works great |
Originally Posted by Keith Atlanta
(Post 3568372)
+1
Works great |
I use tranny fluid in all 4 of my pumps.
| All times are GMT -5. The time now is 10:53 AM. |
