holes in thermostat.......
if i decide to run a thermostat...and i drill the holes in it as most recomend...do i still need a thermostat bypass? im tunning super comp jet boat headers with a bravo drive. (open egnine bay) using the sea pump as a means of water supply. i dont think i will need a thermostat at all.......but in case i do i was just wondering.....
thanks! |
just wanted to add:
i am running a dual outlet thermostat housing with both outlets running overboard for my engine water dump. the water for my headers comes from the auxillary outlet on the crossover tube and is controlled by an adjustable RPM window switch and a solenoid valve. the header water turns on at 1500 rpm and off below 1500 rpm. since my header water is not coming from the engine but rather a raw water source....shouldnt i be able to drill the holes in the stat and run it without a bypass? i only got to test run the boat a few times before winter set it in and temps were not a problem...but im just planning ahead for spring just in case. thanks. |
You can pitch the thermostat, but you may need a restrictor instead to slow down the water enough to absorb the engine heat.
Originally Posted by seltzer
(Post 3572413)
ok cool. what does the restrictor look like and where do i get one? can i just make one??
thanks! |
fixx
Originally Posted by 2tonchevy
(Post 3572823)
thanks! http://www.jegs.com/i/JEGS-Performan...oductId=756441 |
(Post 3572823)
thanks! can be found at any speed shop or probably jegs or summit. if i recal they come in a pack of 3 w different sized holes. |
| All times are GMT -5. The time now is 06:34 AM. |
