Below waterline sealer
What do you use for sealer on trim tabs and fittings?
5200 4200 ??????? |
I would use 4200.
+1, 5200 sucks if you are trying to keep the area clean looking, 4200 works the same but is easier to work with and clean up
Originally Posted by onesickpantera
(Post 3575491)
I would use 4200.
ROCK ON !!!!!!!!!!!!!!!!!!!:coolcowboy: ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!:drink: HAPPY HOLIDAYS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!:bigbird: |
yeap..4200..only use 5200 on something you will NEVER want to remove !!!
4200 has the same sealing as 5200 with 50% of the adhesiveness.
5200 is for permanent and 4200 is for semi-permanent installs. |
What is the brand of those numbers?
Thanks |
3m
3M adhesive sealants
http://solutions.3m.com/wps/portal/3...beQH8HT14PGTgl |
| All times are GMT -5. The time now is 02:13 PM. |
