Alpha to Bravo
Are the lower cables the same length?? Changing to bravo with a remote shift bracket.Don't have t/assembly yet .Thanks for the answer. R.
Doesn't matter if they're the same length. The cables themselves are different. You will need to replace everything from the bellhousing back, including the shift cable.
ditto...
Alpha to Bravo
I'm going to remote the shift bracket. Need to know location limit before I mount. Repower project so slate is clean.Thanks for response. R.
| All times are GMT -5. The time now is 07:10 PM. |
