-   -   rocker arms Stud or Shaft, Crane or Comp (https://www.offshoreonly.com/forums/general-q/267741-rocker-arms-stud-shaft-crane-comp.html)
Advantage 575 12-25-2011 09:23 PM
in the process of finishing my 540 SCI builds. Now looking into rocker arms type and styles. I have Comp Cams Ultra Pro rockers and several sets of Crane golds. Which ones are best for Hyd. roller .60 lift? Also when is a good time to go to shaft mounts like Jesel? Going to spin engines to 5800 RPM.
endeavour32 12-25-2011 10:10 PM
Skip both of the brands you listed. Crane Golds are not as good as they used to be. Buy the Scorpion Endurance Marine Lifters. These are the same as what are used in all Merc Blue Engines.
JasonKelowna 12-25-2011 10:37 PM
go with T&D shaft rockers if you want the ultimate in reliability
mikes280 12-25-2011 10:49 PM
bingo:evilb:
Advantage 575 12-25-2011 10:58 PM
thanks, who sells them? I've been looking around
JasonKelowna 12-25-2011 11:10 PM
(775) 884-2292 T&D Machine products. Call them directly, they are great to deal with and will be able to sell u a shaft rocker system thats built just for your brand of heads
P.s.- go with the 1 piece intake stand systems instead of the individual stands, and once you set them all up get the exhaust stands welded to the intake stands. Then you will have an extremely stable and solid valvetrain. :drink:
Jeff P31 12-25-2011 11:21 PM
T&D is the way to go , just not for the faint of wallet . $1363.00 for a set to fit my brodix head's and 3 weeks for delivery .:eek:
JasonKelowna 12-25-2011 11:33 PM
I hear ya, i just purchased 2 new sets of the steel shaft rockers with spring oilers, 1950 per set but man are they some nice pieces!!!!
JasonKelowna 12-25-2011 11:37 PM
I will never buy anything but the best of the best for my valvetrain components, when cheaper **** breaks it costs much much more in the long run to fix what gets destroyed when low end parts break.
Jeff P31 12-25-2011 11:38 PM
Jason check your PM's
vintage chromoly 12-26-2011 08:57 AM
at 5800 rpm, shaft mount rocker arms are overkill.
a good set of crower or comp cams hi tech will give you 100's of hours of trouble free operation!
if you want to spend three timrs the money then t&d is a great way to do it but, unless you are spinning the engine to 7000 and have monster valve lift and high spring pressure, you don't need it.
t&d is super stuff! on an all out high rpm race engine, it's money well spent! on a relatively mild mill that will never see 6000 rpm it's money wasted!
pqjack 12-26-2011 09:03 AM
+ 1
Raylar 12-26-2011 11:21 AM
I think I would agree here on maybe a little bit of overkill using the T&D shaft system on these N/A mild build engines.
Good ARP studs, stainless roller rockers and some stud girdles should give you all the stability and life you need for .600 lift hydraulic roller and 5800rpms. Make sure the oiling is good as this item overlooked kills a lot of valve train on BBC's , stay with fairly light valve weights,obviously put good money in proper springs,cnc'd retainers,locks and put good valve guides and valve guide clearances where they need to be. Also take time and effort to get pushrod lengths correct and set rockers arm contact patches properly on the top of the valve including guide plate left right alignments.
A lot of valvetrain wear, issues and failures that arise come from things other than the rocker arms at mild rpms.
Best Regards,
Ray @ Raylar
thumper038 12-26-2011 12:02 PM
Originally Posted by Raylar (Post 3579395)
I think I would agree here on maybe a little bit of overkill using the T&D shaft system on thse N/A mild build engines.
Best Regards,
Ray @ Raylar
+1
Very well put Ray!
Happy New Year!
Jim
Advantage 575 12-26-2011 06:57 PM
build engines.
Best Regards,
Ray @ Raylar
Thanks Ray and Jim
My engines are SCI's not N/A's. Cam lifts are .665's. Boost is 9lbs at full load. My original Cranes on one engine seem a little loose. ComP Ultras not so much. You still think stud rockers are OK? Pushrods are .080 Manleys.
Raylar 12-26-2011 07:28 PM
Now with some more info about the engines ( I missed the SCI in your first post) I will change my recommendations. With supercharging and 9lbs of boost at that rpm and nearly .700 lift, the horsepower and pressure loadings will be a lot higher on the valvetrain. I think the shaft rocker system for those engines is a worth while upgrade and cost justified as higher spring rates and pressures will add stress to the rocker system. If spring pressures recommended with the camshaft grind with boost pressures at 9lbs are as high as I think they may be the valve train stresses will need a sturdier shaft support system and rockers. I also like valve spring oilers if you can see to use them and at higher sustained rpms, they really make spring packages and rocker systems last longer with less issues. Based on final open spring pressures the pushrod strength will also be big factor so be sure to use good aftermarket units from someone like Manton or a good equal . Keep the strength and material of the pushrod in mind more than just wall thickness. Sounds like a good high strength lightweight 7/16" diameter is in order. You may also be pretty close to what I consider the limit of .827" hydraulic roller lifters depending on your final spring pressures.. You may want to consider bushing the block for min. .842" lifters like those that Isky and Morel make for higher rpm and boost pressures from supercharged and turbocharged applications.
Best Regards,
Ray @ Raylar
KAAMA 12-29-2011 10:01 PM
Stud mount vs shaft mount---Have someone push you while standing on 1 foot vs 2 feet and you'll get the idea real quick
Advantage 575 12-31-2011 01:12 PM
Well put. All the experts, Raylar, Maderia and Cam Motion agree shafts for my application is better and not a waste off $$. Ordering shafts from M. Kinetics
KAAMA 12-31-2011 05:36 PM
With a stud mount rocker arm system you need to buy the studs, and pushrod guide plates, and some applications may require a stud girdle system.
For a little more money, a shaft mount system already comes with the mounting hardware...besides already having a built-in stud girdle system (of sorts) just by the superior design and no need for pushrod guide plates, and proper alignment either. It's a pretty cool designed integrated system in one.
