KE exhaust in salt water
How does the KE aluminum exhaust hold up in salt water? Are they lined at all? What about airgap intakes?
I run fresh water 75% of the time, but don't want to throw money away by buying parts that aren't going to last. |
I've been running 2 sets for close to 10 years in brackish chesepeake bay water and have zero issue with corrosion. Where I launch the boat is near 100% fresh water though so the KEs get a good flush after each use out is salty water. I think they will work great for you if you flush them well after use in salt.
They will last a lot longer than cast iron in salt.
Originally Posted by Expensive Date
(Post 3581951)
Same story as Blue Thunder ... flush them and you'll be fine.
I ran the air gaps for a couple seasons with no issues . |
Originally Posted by tnc110
(Post 3582092)
If that is true, then great! same story with the intake? I thought saltwater and aluminum didnt jive?
| All times are GMT -5. The time now is 12:43 PM. |
