Originally Posted by 1 MAIDEN AMERICA
(Post 3582909)
What size BV's are people using?
Strainers I have are 1" NPT H2O Pumps I have are 1" NPT Original hose was 1.25" from PU, through pump, to engine. Most PU's I see are 1.25" I've seen transom plate adapters that are only .75" NPT where stock was a 1.25" neck. How much HP can a .75 NPT feed? How about 1" NPT? |
Typically they are done in 1" NPT. That is roughly the same size as 1 1/4" hose. If you add ball valves, be sure to get "full flow" ball valves. CP Performance has some nice SS full flow ones. I think they are about $60-65 each for 1" in SS. You could also check McMaster Carr or Fastenal.
Eddie |
Originally Posted by US1 Fountain
(Post 3583755)
I always thought any water hose below water line are supposed to be double clamped. But then Merc doesn't follow that ruling, so..???
I always found it funny that the suction side of a raw water system required two clamps but yet the pressure side only requires one.
| All times are GMT -5. The time now is 09:11 AM. |
