496 cams
Does anyone know the cam id numbers on Merc 496's? I need to know the difference between HO,mag,and truck.
I have 4 --496 Mag cams..do you want the stamping of the cams??
I was told that the mag cams are truck cams..not sure if true or not |
Yes,i need the number stamped on the cam.
ttt
There are no numbers stamped in stock GM camshafts for 496 -8.1L engines. the numbers on the ends of the crankshafts are core numbers that are lasered not stamped and these camshafts are not for purchase from GM. Raylar has replacement new billet camshafts for 496's and I think our profiles are better anyway. You may be able to find a used HO camshaft with a listing on here or in the parts swap section.
Best Regards, Ray @ Raylar |
Originally Posted by checkeredpast
(Post 3593450)
I replaced it (as it had been for a swim and was corroded) with a factory part number 881628. Cheers CC |
Thanks,that is what i need to know!
| All times are GMT -5. The time now is 04:01 PM. |
