-   -   500EFI Whipple on 454 MPI Mag???? (https://www.offshoreonly.com/forums/general-q/268989-500efi-whipple-454-mpi-mag.html)
justinp20012500 01-18-2012 10:10 AM
I found a really, really good deal on a Whipple supercharger for a 500EFI for a 502.
My questions is this... Can I make that charger work on my 454 MAG?
Can I take the parts of this system and add some new whipple components to make it work?
I believe the 500 efi charger is about 8 years old.
And if it can't be done... Anyone out there want to sell me a bolt on supercharger for my 454 MPI MAG?:D
4bus 01-18-2012 10:20 AM
Call Dustin @ Whipple, great guy and no BS.
mr3dman 01-18-2012 10:21 AM
why not? Only thing I can think is at worst you may need to change the fuel press or efi map for the 454I would contact whipple to be sure. I'm sure someone else will chime in
justinp20012500 01-18-2012 10:26 AM
I have found a few eBay setups and had questions. Left roughly 5 voicemails for Dustin and no return phone call...
justinp20012500 01-18-2012 10:28 AM
Also, the kit I have found will come with the 500EFI upper and lower manifold.
Will the lower intake on the 500efi fit my 454 MAG heads?
A.O. Razor 01-18-2012 10:37 AM
Welcome to OSO.
What kind of power are you looking to make? You can try and contact Dustin here on OSO, goes by the name Whipple Charged. Besides having a fuel system that can keep up with the power, you should look into an oil cooler and raw water supply that is up to the task as well. Are you running a standard B1 drive? Full hydraulic steering? I'm asking these questions because every piece of the setup is part of a reliable setup.
Good luck with it.
4bus 01-18-2012 10:45 AM
Yes, GM BBC rect port heads. I think your fuel system is different on the 454 MPI, but not sure
4bus 01-18-2012 10:46 AM
Um, you have to leave a creative message.
Call again and tell him you are looking to buy 2 new quad rotor whipples for your boat. When he calls back tell him you were just joking, and need help setting up a used whipple :lolhit:
justinp20012500 01-18-2012 10:51 AM
Originally Posted by A.O. Razor (Post 3596099)
Welcome to OSO.
Good luck with it.
Thank you, been lurking for sometime now. Mostly cruising the classifieds.
What kind of power? As much as I can with my current power plant.;)
Does the MPI MAG not have an oil cooler? Thought it did...
No on the hydraulic steering, it is on the list.
A.O. Razor 01-18-2012 11:08 AM
Not one that is up for 650-750 hp imo. Get hydraulic steering up on your list, It is what I like to call mandatory with this kind of power and speed. What boat are you running?
