Merc 420 vs 440
I'm in the process of rebuilding a set of 454 Mags to either the 420 specs or the 440 HP specs. I'm curious if anyone has experience with both of these engines and if there is a reason why I shouldn't use the 440 cam which as far as I can tell is the Lunati 00026 cam.
Yes I know roller is better, and if I could swing it I would have Bob build me custom roller cams, but I don't have the coin on this build for roller cams, custom push rods, roller lifters, ect. Flat tappet is what it is. |
The cam used in the Merc 440hp engine was a hydraulic flat tappet made by Ultradyne...something like 231*/239* @.050 .550" lift Intk and .558" lift on the exhaust with 110* lobe seps.
I always thought the cam used in the Merc 440hp was a bit too much cam for a 454cid marine engine. It had a slightly rough idle, but not too much that you couldn't stand it---but I thought the idle sounded really good with headers. It would probably idle slightly better if ground on a 112* lobe seps. I believe I still have one of Merc 440hp cams NEW in the box from Ultradyne if you're interested. |
Your correct it was an Ultradyne cam, but I'm pretty sure Lunati is now making that cam.
Here are the specs on the Lunati cam •Advertised Duration (Int/Exh): 293/310 •Duration @ .050 (Int/Exh): 232/239 •Gross Valve Lift (Int/Exh): .549/.558 •LSA/ICL: 110/104 What I'm curious about is dock manners as well as characteristics at cruising 3000-3500 RPMs. I'm running Gil's Dry to the tip so I'm good on reversion, I think. If you had two cams I would be interested as I'm building two engines. |
Originally Posted by endeavour32
(Post 3597693)
Here are the specs on the Lunati cam •Advertised Duration (Int/Exh): 293/310 •Duration @ .050 (Int/Exh): 232/239 •Gross Valve Lift (Int/Exh): .549/.558 •LSA/ICL: 110/104 What I'm curious about is dock manners as well as characteristics at cruising 3000-3500 RPMs. I'm running Gil's Dry to the tip so I'm good on reversion, I think. If you had two cams I would be interested as I'm building two engines. Just some general info. I always had good luck with flat tappets. Just break them in right and get on with it. Since you have that dry exhaust, I have a bad ass set of flat tappets I will sell you cheap. THey will make close to 500 on a 420 merc with dry exhaust and oval port heads. |
Just get this Crane cam and call it good. Budget priced for a cam/lifter kit. It pulls strong to 5400-5500rpms.
http://www.summitracing.com/parts/CRN-134242/ |
| All times are GMT -5. The time now is 09:19 AM. |
