-   -   Outdrive Stand - Need drive Measurements?? (https://www.offshoreonly.com/forums/general-q/269308-outdrive-stand-need-drive-measurements.html)
East Coast B 01-23-2012 04:36 PM
I'm making an outdrive stand with jack and will be making the space between the two pieces that connect with the drive 4 1/4" apart.
MY QUESTION:
Will all drives, bravo1, bravo3, alpha, SX, DPX fit between the 4 1/4"?
If not, I'm thinking of making that piece adjustable so I can widen to fit other drives. Else, I'll just weld it at 4 1/4".
Thanks!
johnnyboatman 01-23-2012 04:41 PM
i took a motorcycle jack and flipped the mount upward and cut the center out worked good for me
rrentsch 01-23-2012 06:41 PM
You will be fine at 4 1/4" all of mine are 4"
atg 04-21-2013 09:48 AM
4 1/2 isn't big enough for a Konrad 520 I'm pretty sure. Depends whether you want it to sit on the flat plate or the nuts but I think the housing itself is wider than that.
