496 Raw Water Pump Rebuild
Im not sure when the Impellor was last replaced in my 03 Sunsation 288 w/ 496 Mag and i want to replace it this spring. This is my first 496 and i know the housing is brass and runs $400+, has anyone eve used one of the "rebuild" kits for this pump? JC Marine makes one that comes with new impellor, gaskets, wear plates etc....Also i dont like the idea of drawing the RV antifreeze up via muffs, i have read where guys install a tee fitting in the supply line just before the pump what kind of tee fitting do you use?
Here are some more
http://www.cpperformance.com/c-132-m...sea-pumps.aspx |
Buy the CPPerformane/Hardin Marine 496 stainless pump and you've solved all your current and future 496 raw water pump problems. This pump has the Raylar 496 Stamp of Approval.
Best Regards, Ray @ Raylar |
Originally Posted by Rockfish71
(Post 3612063)
Here are some more
just ordered the hardin marine $349 all stainless. Gonna put it on next week, plus the rebuild kits are cheap.
Been running the Hardin Marine stainless raw water pump now for a year and all good thus far! Caught a lot of flack for not buying a "rebuild kit" for the stock merc one. Was not a fan of grinding and silicone! The difference between the rebuild kit and the Hardin stainless entire replacement was only like a 250.00 bill! A LOT of material!!! Lovin it!
(also uses an old school impeller/much much larger and thicker internal shaft!). |
(Post 3612063)
Here are some more
