bbc magnum intake manifold question
1 Attachment(s)
Hey folks,
I have an aluminum magnum manifold with the inserts in the cooling passages. The aluminum has corroded a bit but the bronze still looks sound. This is what it looked like when it came out of the parts washer and media blast. Take a look at the pic. The sealing surface looks good too. Would you use this or trash it? |
That's the way most of them looked brand new, poor casting but fully functional.
I thought it looked sound. What would be a good product to fill the gaps in the aluminum prior to paint?
I am going with closed cooling so in reality I don't need an intake with the bronze inserts. ...I own it so I guess I'll use it though. |
I had one of the 2 on my boat looked like that. I just used some JB Weld to build it up and make it smooth.
jb or marine tex. no water leaks? no vacuum leaks? is it paid for?
[QUOTE=dereknkathy;3612869]jb or marine tex. no water leaks? no vacuum leaks? is it paid for?[/QUOT
paid for but not enough to stress over if its trash . |
Poor quality control in the casting department as many look like that- should be no problem.
[QUOTE=jmz;3612882]
Originally Posted by dereknkathy
(Post 3612869)
[QUOTE=stevesxm;3613181]
Originally Posted by jmz
(Post 3612882)
i understand all thats been said here but for the couple hundred bucks a new and much better manifold would cost i can't imagine its worth the time and effort to fix it. |
[QUOTE=jmz;3613221]
Originally Posted by stevesxm
(Post 3613181)
I hear you but what time and what effort? They all need painting so no extra time or effort there and smearing some epoxy of some sort to fill the voids is about 15 minutes of work the way I see it. |
| All times are GMT -5. The time now is 03:49 AM. |
