What oil coolers?
What oil coolers are you guys running on your supercharged bbc also what temps with your cooler. I am updating from the stock thanks james.
540 BBC Procharger stage 4. Eddie marine's biggest 2 section cooler. Engine oil & PS oil. Used with permacool t-stat. I do not have temp gauge but since I have done this the oil pressure comes down from over 80 to 70 fairly quickly now. Pressure has not gone below 70 where before would go down to 50-55 after hard running. Lake water temp last weekend was 80 if I am not mistaken.
Jack how big is it also where did you mount it??
SACARBAJ,
That thing is huge! Check their website, it gives dimensions. Better plan on all new hoses as stock may be a little short. Do a search on this topic. Lots of debate on size of lines. Go BIG on the lines, You want at least 1/2 ID. Be careful in fitting selection as many are necked down much smaller that the hose. Tim T. |
| All times are GMT -5. The time now is 03:25 PM. |
