Hydrolic fluid for K-Planes
What is the right fluid to fill up the res. for my K-planes, it is a yellow fluid, but what type exactly????
Thanks WILL:rolleyes: |
Ill have to check the manual but I think its regular 30 weight motor oil.
Ron |
I appreciate it
WILL:D |
Cant seem to find the manual for the tabs but for the trim pump it says to use Quicksilver Power Trim and Steering fluid or SAE 10W-30 or SAE 10W-40. It looks like the same oil in the trim and K-Plane pumps in my boat.
I have read somewhere in the literature I recieved with the boat about the K-Plane fluid and I remember it to be regular motor oil 10W-30. Maybe someone else will know for sure. Ron |
got the install manual - 10W30
Mine have a little sticker that say.. " ATF" atumative transmission fluid..
The fluid in my k-planes was red as in trans fluid when I changed the out-board lines, Fred
I am under the impression too, that, you can use ATF-automatic transmission fluid in some reserviors. I know I can with mine. Make sure you know what fluid to use!!!!!!
I haven't topped mine back up yet so I need to check to see what mine requires.....although it is red like trans fluid....Fred
You can use almost anything:
10w30 Power Trim & Steering Fluid Hydraulic oil ATF . . . but what ever you use, you should be consistent and not mix different fluids. The lower viscosity oils, like power trim & steering fluid or hydraulic oil, makes the K-planes or power trim unit move faster than with the higher viscosity oils, like 10W30 When in doubt as to what oil you have in there now, you should pump it out and put in all new oil. |
| All times are GMT -5. The time now is 01:07 PM. |
