These are the mufflers we have now.Tested with dB meter at the dock,barely passed the 85 dB .
http://www.youtube.com/watch?feature...&v=QtMEmWhSRJo Inside without the engine box. Loud! http://www.youtube.com/watch?v=6L-st0izosU |
Rubber external flappers are the safe way to go on your set-up !Have them on my Teague Select Exhaust System and they work very well....
Jim |
Now THAT is the way to commute...a practical all-weather offshore boat. Very cool.
Originally Posted by spectras only
(Post 3624708)
Friend built his 34' boat a few years ago with a single engine in mind.We've opted for the ZZ572 engine with Stellings dry exhaust.It worked great until the inner jacket at one of the exh flange cracked and doused the exh valve and dropping it.We had to scrap the dry exhaust idea and had Eddie Marine fab a s/s wet one to our spec, mounted on the EMI aluminum unit.We had to get the risers taller than the stock units readily available to stop reversion. 500 hrs on the engine and boat ,running top as a commuter on weekends.
Original setup http://www3.telus.net/spectrasonly/c...20interior%201 http://www3.telus.net/spectrasonly/c...20interior.jpg http://www3.telus.net/spectrasonly/IMG_1858.jpg http://www3.telus.net/spectrasonly/IMG_1052.JPG Present setup http://www3.telus.net/spectrasonly/C...rine%20exhaust Sorry Baywatch :hijack::lolhit: |
Flappers will help with water ingestion when the boat is sitting at the dock/mooring and waves come over the pipes but they will not help with reversion while the engine is running.
If you have gills, I really think you're fine Josh. Your cam is smaller than the 731 the HP 500's had and they were built originally with Gils and silent choice. http://www.cranecams.com/product/car...detail&p=24282 |
awesome boat...nice mix of nostalgia and hi-tech...
Originally Posted by POWERPLAY J
(Post 3626696)
Very cool! Do you have pics from start to finish?
.He used a windshield from a SeaRay for his boat, rest of the boat is a one of. You can see more info I put on at > http://www.riverdavesplace.com/forum...ead.php?t=4456 |
Thanks for the info. He did a great job. I dig it!
