-   -   which bravo drive coupler? (https://www.offshoreonly.com/forums/general-q/271667-bravo-drive-coupler.html)
rivermonkey 02-29-2012 01:29 PM
Hi
Im gonna replace my drive coupler while the motor is out, should i be using a steel hub ( like avail at CP Perf) or a merc aluminum hub? The CP is an HP unit and is much cheaper, but ive read mixed reviews about steel vs alum. My motor will be around 500-550hp eventually, so im planning ahead.
Thnx
GTOFFSHORE 02-29-2012 02:15 PM
First there is 2 different styles of couplers. Dick or non dick version. I have a good merc one here with the dick for 200 like new.
Griff 02-29-2012 09:00 PM
Use a steel coupler. You can use the one with a snout or without. All of the long snout couplers are steel. They used them on 575SCI's and diesel packages.
