-   -   SBC Exhaust (https://www.offshoreonly.com/forums/general-q/272003-sbc-exhaust.html)
johnnywhale 03-06-2012 04:56 PM
SBC Exhaust
Stainless Marine vs. CMI E-Tops
Any peformance difference on slighty warmed over 350 - 400 hp sbc?
Just bling?
Problems with CMI leakage?
Thanks,
Johnny
Anyone with ones they want to sell?
Ryan00TJ 03-06-2012 07:46 PM
I would also like to hear opinions on this.... Currently running GLM tuned manifolds with Imco FastGlass 22" long dry risers on my 475hp 385ci SBC. Thinking about upgrading if the power gain is there.
Dangerous Dave 03-06-2012 09:36 PM
I've been running Stainless Marine manifolds and full length tailpipes since 2005. They've been on and off the motors a few times for various reasons and I've carefully inspected them as good as I could every time and they are like new. The tailipes are dry until 1" to the tip so reversion is no problem even though my cams arent that big (yet) but technically speaking they're almost dry.
They replaced Gil manifolds that failed due to corrosion. I believe they were original from 1985 so no crying here. My boat spent 1/3 of its life at Ft. Apache in Miami (salty) 1/3 in the great lakes and 1/3 with me in Tampa Bay and the Gulf which has very salty water. I flush religously and thouroughly with fresh water then mixed with Dawn dish soap.
I can't relay any performance comparisons because I never did a straight exhaust swap, lots of other stuff was done too, but these have held up great and I know I've seen a bunch of threads in recent years about leaky headers and I have no real world experience with CMI's new SB headers so I can't say anything bad about them but I will give a thumbs up to the Stainless Marine stuff.
Dangerous Dave 03-06-2012 09:40 PM
1 Attachment(s)
Heres a picture just for the hell of it.
the deep 03-06-2012 10:19 PM
I have a set of fully polished CMI E-tops with dry tailpipes . Ran only about 60 hrs on my 383 ci before i bought the cat . Never had a problem with them . They were run in freshwater only in our local lake and never subjected to a severe pounding . They can pass for new except where the engine box was touching on the top of each header . Just fine scratches that can be buffed out . They also have the polished distribution tubes . They sound kickazz and made little kids on the dock cry when i fired her up !!! Was not going to part with them but i need money for the Warlock build ....:bunnydance:
the deep 03-10-2012 07:55 PM
Just bling?
Thanks,
Johnny
Were you really looking to buy or ............:whistle:
johnnywhale 03-11-2012 03:54 PM
pm sent
the deep 03-14-2012 01:07 PM
Put your sunglasses on boyz . T-bag These .
http://i1243.photobucket.com/albums/.../headers-2.jpg
http://i1243.photobucket.com/albums/...p/100_0343.jpg
http://i1243.photobucket.com/albums/...p/100_0340.jpg
http://i1243.photobucket.com/albums/...p/100_0342.jpg
http://i1243.photobucket.com/albums/...p/100_0339.jpg
http://i1243.photobucket.com/albums/...-Copy-Copy.jpg
the deep 03-14-2012 01:49 PM
Just showing pictures Speedgirl , not for sale YET !! :whistle:
johnnywhale 03-14-2012 04:14 PM
How big are the primary pipes?
Can you measure distance from rear flange bolt to both rear weld joint and to exhaust tip?
Thanks,
Johnny
the deep 03-14-2012 07:42 PM
Thanks,
Johnny
Ok Johnny , the tail pipes' will swivel in every direction so with that in mind....rear flange bolt to rear weld...10 1/2 to 11 1/4 " . Rear flange bolt to tip 19 1/2 to 20 1/2 " . Both measurements you could probably stretch a bit more in either direction . Both measurements taken from center of last mounting bolt hole at transom end of head . Now , if you look in the pictures you see a mounting plate that bolts to the head first , then the header mounts to that . Exhaust holes in the mounting flange are 1 1/2 " in the headers they are 1 7/8 " I .D . You can also get a little movement out of the mounting flange . Tailpipes' are 4 1/2 " diameter . These were on an OMC setup so should be the same as your Volvo .
jray1010 06-17-2012 08:04 PM
cmi headers
Have you sold the headers yet or ready too? If you want to sell them give me a call at 315 623 9583. Thanks jim
Trash 06-17-2012 10:48 PM
Just bling?
Thanks,
Johnny
I don't think you will see any advantage using those exhaust systems at that HP level. I'm spinning a 377 SBC to 5600 so far with GLMs and Ryan has spun closer to 6000 rpm with GLMs if my memory serves me correctly. So I don't think exhaust is the limiting factor at the 400 hp level in a SBC. If you want to wind them up to 7000 rpm (:eekdrop:) you may want to invest in the CMIs.
From my perspective I would much rather spend the $3000 in engine internals rather than JUST on a set of pipes.
Having said that CMI's do look good.
