what blowers to use on stock 330hp?
what blower can i safely use on my stock 454 330hp motor a weiland 174? what do you recommend
The bilge blower is the only safe one for your application.
i know they wont last but i like to run them on there then on my new motors i could still use the blowers
danger will robbbbbbinson
It might not end that bad that quick. I would def go with the 177 bit if you plan on going to bigger cu in then go ahea and use the 250.
I did this back in the day and got about 20 hours on a fat tune until a rod checked out because a piston melted. It is a for sure way to upgrade. |
as long as you are upgrading, get the biggest blower you can. run about 30 lbs of boost. you'll be upgrading by the end of the day. or better yet, sell the 330's instead of blowing (pun intended) them up!
Originally Posted by JasonSmith
(Post 3635153)
I know of 3 cast BBC engines that have been running on blowers for years.
2 330 hp running a 174 and a 177 4.5lbs 1 310 hp running a procharger 5 lbs with aeromotive fuel system the 310 blew up last year, because of overheating, it has been on that boat for years however. He had a water issue but kept using the boat. The other two no problems, they both even have square port intakes going to peanut heads.....all 3 single engine boats gained 10mph +/- The thing you have to understand is if anything goes wrong, just a little, you will pop them. you will have to be conservative on timing and fuel trim. Just a little knock and you will be grenading. Fuel and water gauges should be added for extra security. A stock 330 hp will prob run for 30 mins with low water, let it cool and go. Add a blower and that same engine would have trouble running for seconds hot under boost. However, this is also true on most boosted engines, things happen fast with a blower. Forged components however can handle a longer duration of knock and ping. They also can be overheated somewhat without coming apart. IMO go for it, you have the cheapest long block BBC you can buy, remans are out there for $2k! Destroy a 500 hp with a blower and you may be out $6-8k! I would also do a 250 style blower, the 174/177 makes a lot of heat. Do the 250 with the single carb plate, you can always add twin carbs later when you build big power. |
sounds like a good idea
If you just want it to blow up after a few hours, well PSI or Whipple can help you with that. But then again you leafblower will prolly do it too. Why do you want to put money into an engine that is not supposed to last? Even if you only want it to last a short time, you'll still need parts to go with the blower. Fuel system, cooling ect. Save the money, sell the 454 and build yourself a nice 509-532 9.8 deck BBC. Also remember that if you are really unlucky, the engine failure will take out the sc as well. If you MUST do it, get a cheap 177, sell the sc when the motor is done for and start with a clean slate.
Originally Posted by 4bus
(Post 3635375)
I have been running a Procharger with 5lbs for 5 seasons on a stock 1995 engine with no issues yet. Don't let people scare you. Kee the rpm's within the stock limit and make sure your fuel system is more than you will ever need and boost referenced and you will be fine. Any questions let me know.
did a 330 hp running a 177 @ 5lbs 3 years ago and its still running on the lake and only done oil changes . go for it you'll be fine
I still have the setup i ran on 330 twins successfully for a year, then put it back to stock and sold it! What a hoot, picked up 12MPH with prop change. The blowers were 250s! Never did bend the sticks over and forget them tho.
im ging to go with the 177
Put 60 hours on a stock 454 running 6-71 @ 6.5 lbs boost. Boat still runs like a top. PM me if you want details, be glad to help you out.
Originally Posted by mookster
(Post 3636762)
(Post 3636762)
Get a chiller if you can, if not get a 250 and lower your intake charge temps! Lower temps mean more consistant power, and less chance of det if your engine does get a little warm. This is a good deal! http://www.offshoreonly.com/classifi...o44357-en.html single and dual plates included, 4 carbs, you will have what you need now, and what you may need in the future. |
Sounds like it will last longer than you think.
We put a 468 cheepy together years ago cast crank, cast trw pistons, hyd flat tappet cam.
Balanced the mess up and ran it nat for 4 years in a tunnel jet ........beat the snot out of it, then we put a rec port intake on the ovel port heads and a street 671 with a pair of 650 cfm hollys on top locked the timing at 30* with 8lbs boost beat the snot out of it another 3 years then sold the boat everything still running like a top ......the boat ran 82 nat and 98 mph blown. |
| All times are GMT -5. The time now is 07:23 PM. |
