Motor mounts - baja
I purchased a baja 24 outlaw without power. The front motor mounts that came with the boat are the type that attach to the top of the stringer. These mounts have no adjustment. Instead where the large stud would normally be just looks like a solid bushing that is bolted from the engine motor mount down. Has anyone heard of this? How is alignment adjusted with these? I wouldn't mind going to the stock setup which I think is normal Merc adjustable mounts with some sort of guard that covers the stringer bolts and is thru bolted by one bolt thru the stringer. Has anyone heard of this kind? If so where can I get the cover piece? I have a hole in the stringer for this cover piece.
ttt
Pictures are worth a million posts.
1 Attachment(s)
are these what you are looking for i also have the other half that attaches to the block but they are still on my engine in Florida but i should be able to get them shipped if needed
I don't have a picture of what I'm looking for because the boat doesn't have them on it now. The following thread has the type that came with it stock I believe. I'm just looking for the stringer side.
http://www.offshoreonly.com/forums/d...lts-loose.html How do I post pictures? On the lower left of my screen under posting rules, it says You may Not post attachments. |
Originally Posted by FBRONCO
(Post 3636246)
Is this what you are talking about?
http://i116.photobucket.com/albums/o...Picture001.jpg http://i116.photobucket.com/albums/o...y/IMG_0092.jpg |
Yes. Those are it! Looks like stock merc mounts with that cover piece that is through bolted. I'm sure I could get the stock merc mounts somewhere, but where do I get the cover piece? I'll be pulling the transom assembly and k-planes this weekend so I can clean/sand/smooth and paint bilge. I will upgrade my membership so I can attach photos of the mounts that came with the boat. They are not adjustable, and was wondering if anyone has seen this type before. Maybe they are better than stock Merc, but I don't think I like the non-adjustability factor.
1 Attachment(s)
I don't know if I still have the 'covers' or not, I'll take a look in the next couple of days and see. Pretty much all they do is keep the lag bolts from backing out.
From what I recall all they were, was a piece of angle aluminum slotted to go around the mount. |
2 Attachment(s)
Here are pictures of my solid non-adjustable motor mounts. Ever see these?
