Twin engine power steering
Mercury has a kit available to allow you to plumb both power steering pumps to a valve that feeds a hydraulic assist steering set-up, Does anybody know what this part number is?
Thanks |
Give IMCO a call. They have valving systems for twin application . Part # PT13 page 85 .
http://www.imcomarine.com/nvcatalog/imco_catalog.pdf |
hyd assist power steering? by that you mean the stock inside boat pass car-style power steering? if so, what advantage to 2 pumps? i think spectras is thinking hyd steering, not cable-to-tiller PS.
Only advantage I can think of would be if you lose motor that has the pump you could somehow switch to the other motors pump.
Example: My boat drives power steering off of Port motor. When I lost the engine coupler, I had to limp back on the Starboard only. I was able to keep the Port motor running to use the power steering but what if there was a problem with that engine, bearing or rod failure? Then no power steering and with twins and dual rams... turning is a BIATCH! |
Originally Posted by Chico&Zeus
(Post 3644580)
So the blaance vlves dont have a check valve? to stop that from happening?
Originally Posted by mittens
(Post 3644598)
Originally Posted by dereknkathy
(Post 3643111)
http://www3.telus.net/spectrasonly/E...ect%20complete And yes ,I want to have the valve for two p/s pumps.I lost power to my starboard engine with the p/s assist due to drive breakage and it was a sum***** to turn the wheel limping home.The added hydraulic steering also helped to keep the drive from pulling out completely,leaving the bellows intact, so no worries about water coming through the shaft bearing hole. Here's the carnage http://www3.telus.net/spectrasonly/broken%20bellhousing |
How did that happen?
Originally Posted by endeavour32
(Post 3644990)
| All times are GMT -5. The time now is 05:11 AM. |
