VDO Vanguard Gages
The fuel gauge on my 95 Formula keeps hanging. I start it up and bang on the gauge for a bit to see if it moves one way or another. I've never run out of fuell just appears the gauge is hanging inside. It currently mounts from the back and the hole is less than 2 inch, so if I'm having trouble finding a replacement. I think the gauges are vangaurd series from some research but on the side it says VDO YAZAKI.
Wouldn't mind changing out the hole setup and install another GPS map and not use the water tube speedo. Any ideas? |
Pics
Is there a tool which can be used to make the hole a standard 2-inch?
Some Pics of the issue http://i609.photobucket.com/albums/t...Boat/Gauge.jpg http://i609.photobucket.com/albums/t.../Boat/Hole.jpg |
| All times are GMT -5. The time now is 07:31 AM. |
