-   -   Merc K-Plane 280 Cylider question (https://www.offshoreonly.com/forums/general-q/272742-merc-k-plane-280-cylider-question.html)
low_psi 03-19-2012 04:04 PM
I currently have Lenco HD Sport Tabs (not the cheesy ones that come on cruisers) on my Velocity 260. They are fairly large and have heavy duty electric screw actuators. I was thinking of picking up a set of 280 K-Planes without cyliders, and using the electric screw actuators if they fit. Can someone post the k-Plane cylinder length both compressed and extended? Or post the measurement from bottom of k-plane to where the top of cylider mounts as well as distance from transom plate to where the bottom of cylider mounts. Thank you in advance!!!
low_psi 04-15-2012 10:36 AM
TTT....
Still looking for measurements.........
keith2500hd 04-15-2012 01:55 PM
think you would be better off using the full K-Planes, electric actuators more than likely not intended for that surface area.
low_psi 04-16-2012 10:04 PM
My current tabs are not the typical Lenco tabs.... The hd sport tabs are quite large and may actually have more surface area than a 280 k-plane... Since they are stainless steel, they are probably much heavier than k_plane.... This is a pic before I mounted... These are 14"X18" for a total surface area of 252" inches each.....
http://site.activesportsunglasses.co...city/tabs3.jpg
