| fkboatman |
03-20-2012 11:05 PM |
engine build thought (502) block
Block is 502, motor specs out at 532 inches. eagle rotating assembly, will have 9.5.1 compression ration. after all said and done w/ head gasket,pistons,rod,length and edlebrock heads. will be running merc 525 cam. dominator intake w/ a 850 marine holley. ignition is a marine D.U.I big cap Hei dist. What is a safe total timing number to start with. Engine will run on mid grade fuel. At no more then 300 ft above sea level. anyone have a horse power number? thanks for all the help
