this isnt rocket science just get a perko they are like 30 bucks.
so your saying every single perko switch out there is the same? saying that while there are so many different switches....
I have a spare Perko switch from the Baja that I bought a couple years ago when we were messing with the transom. It is new in the package if you want to trade some parts? Brian
i already ordered a switch but thanks
Originally Posted by regalman4925
(Post 3651911)
perko 8501. only reason i went perko was because i have a perko on/off switch that may be getting installed also and i wanted them to match. hopefully this one holds up better than the last one.
this is what they advertised as far as switching it while engines are running. honestly i want to be able to switch them just in case i run a battery down i can start with the opposite battery and switch it back to charge the low one. next is on board charger so i can charge while at the docks and home. too bad they just told us they are not reopening our marina so i no longer have a slip with power :( For Use With 12, 24 and 32 Volt Marine Electrical Systems Capacity - 250 AMPS Continuous, 360 AMPS Intermittent. When used with Non-Unitized Alternators, these models will interupt the field current (reducing the possibility of damage) if turned "OFF" with the engine running. |
thats the same witch that is in the Baja. It has worked fine for me.... Good luck!
Bumer on the marina.
Going to have to find dry storage with a plug close or get a little Honda 2k gen and a power supply and never worry about running down while on the sand bar. Dont use a regular battery charger with a gen while playing or it will burn up. Need a 30-45A w/ IQ-4 power supply like Iota or Kinetik. http://www.iotaengineering.com/12vdc.htm Also acts as a charger for long term maintance. Might as well get the charger now and install all at once while in there. |
Curious as to why you need an on/off switch in addition to the one you bought? That sucks about Bellevue. I just read that. It appears Dodge Park will be the only marina open on the Mo this year. The ramp at Manawa is already open btw.
Does anyone run a battery isolator? And why don't these switches ever fully isolate the batteries? Even with a two switch setup, one battery still effects the other. It drives me nuts, and I don't get it (which is probably why it drives me nuts).
| All times are GMT -5. The time now is 01:30 PM. |
