How in the Heck do you clean your Hull!!
Hey Guys, Looking for creative ways to clean and wax my hull. My boat sits on a trailer and is too low to get at the whole thing.
Any Thoughts?? |
The parts of the hull that are not reachable should not be waxed as it will make you slower. I wax the bow and hull sides not the actual bottom. I use on/off which is acid to remove any colorization and magic eraser for any scum line. That's it.
X2 I never wax the bottom of the hull, I do however polish it. The best way I found to do it is get one of your boat whore friends to get his azz under the boat and use a little elbow grease. LOL
Originally Posted by rfgonzo
(Post 3650153)
Great answer. I misspoke earlier I don't wax my hull either just clean and polish. Does anyone use a lift or anything like that? 27' Fountain by the way |
Take it down to your local boat dealer or marina. for a couple hundred dollars, they will lift it off the trailer and have one of their hired hands give it a good cleaning and buffing. And if it hits the ground it is on them, not you. I am having mine done right now. Tired of laying under it wiping river water stains off with acid.
And while they have it, it is a good time to do any trailer maintenance that you have been putting off. bearings, carpet, paint etc. |
I use a pump sprayer from Rural King with a diluted solution of Walmart Hull Cleaner and water. Walk around the boat, spray on, hose off. Ohio River stains (and all of the other contaminants that we swim in) usually come right off with the water hose pressure.
Originally Posted by snapmorgan
(Post 3650240)
take it down to your local boat dealer or marina. For a couple hundred dollars, they will lift it off the trailer and have one of their hired hands give it a good cleaning and buffing. And if it hits the ground it is on them, not you. I am having mine done right now. Tired of laying under it wiping river water stains off with acid.
And while they have it, it is a good time to do any trailer maintenance that you have been putting off. Bearings, carpet, paint etc. |
Thanks Guys for the good advice.
[QUOTE=Poker~N~Run;3650111]The parts of the hull that are not reachable should not be waxed as it will make you slower.
:funnypost::lolhit: |
SLIMEY GRIMEY. You can buy it online. Its chep. just mix it with water and spray it on the yellow stains on the bottom of your boat and it will run rt off and be white again. Its good stuff!
On-Off works good but dont breath it in!
http://www.jamestowndistributors.com...ct.do?pid=2339 |
Since I`m in HVAC I use coil cleaner, was amazed how great it works, its acidic. Now I`m worried about having the stains come back so much faster thou..
On my old boat thats what seemed to happen more acid the quicker it comes back especially in brackish water.. I try to wax the front deep vee it keeps it white, i leave the far bottom a lttle yellow
[QUOTE=Jeff P31;3650305]
Originally Posted by Poker~N~Run
(Post 3650111)
:funnypost::lolhit: you shouldn't wax the part of the boat that is considered the running surface. |
[QUOTE=Poker~N~Run;3650664]
Originally Posted by Jeff P31
(Post 3650305)
Somebody got that. :evilb: you shouldn't wax the part of the boat that is considered the running surface. |
(Post 3650305)
[QUOTE=TC G;3650814]
(Post 3650664)
How much slower will it make you? You want the bottom of the boat to have a rough feeling. You want to create bubbles that aerate the bottom. My boat being an f1 race boat was sanded on the running surface. The wax makes the water sticky and it holds to the surface. |
Originally Posted by Josh LaFountain
(Post 3650417)
2 Attachment(s)
[QUOTE=Poker~N~Run;3650844]
Originally Posted by TC G
(Post 3650814)
A friend of mine lost 2mph until it wore off. You want the bottom of the boat to have a rough feeling. You want to create bubbles that aerate the bottom. My boat being an f1 race boat was sanded on the running surface. The wax makes the water sticky and it holds to the surface. |
Power One by Fountain of Youth. Smokes any acid-based product I have ever used.
http://www.fountainofyouthrestore.co...wer_One_1.html |
I will give up a couple mph for a clean boat
I waxed the bottom of my Cigarette Top Gun and gained 4 mph. It was my best speed in 8 years. The water was rough.
I guess when the water is rough , you don't need bubbles. |
Originally Posted by Knot 4 Me
(Post 3650955)
| All times are GMT -5. The time now is 09:16 AM. |
