Amsoil Dominator 15-50 or Z-Max 20-50 ??
Which oil do you guys recommend in my 1050 hp...540?
Spinning 6200 RPM Amsoil Dominator 15-50 or Amsoil Z-Max 20-50 And why? Chris |
My choice would be the Dominator Racing, but here are the links to both data sheets. Both products will work great in your application.
http://www.amsoil.com/lit/databulletins/g2570.pdf http://www.amsoil.com/lit/databulletins/g2883.pdf |
Thank you
Also, the dominator racing actually has more zinc and phosphorus than the Zrod. The zrod, however, does have a bit more of a rust and corrosion inhibitor package built into for engines that tend to sit a while between uses. But you say you're running 6200 R's, I think the Racing Oil would be your number 1 choice.
That is what I was guessing....
I appreciate your suggestion. Chris |
I just asked the same question from Amsoil tech support and they told me Dominator is the way to go for very high performance engines. Z-Rod is designed more for flat tappet engines that are more moderate in power.
| All times are GMT -5. The time now is 09:48 AM. |
