-   -   GM Flywheel questions (https://www.offshoreonly.com/forums/general-q/274248-gm-flywheel-questions.html)
protechcoat 04-14-2012 09:53 PM
be careful NOT ALL 5.7 CHEVYS ARE neutral balance if it is a 1 pc real seal crank it is external on the back and int. on the front.buy the correct flywheel ,bbc will not fit ...
Itsallgood995 04-25-2012 06:12 PM
If I understand all the posts correct a #14091599 1pc external balance flywheel will work on my Gen V 502. correct?
BillK 04-25-2012 07:29 PM
No,
That flywheel is for a Small Block, not a Big Block.
Young Performance 04-25-2012 11:37 PM
The Gen V and VI 502 flywheel has a casting # ending in 805. I have several if you need one.
Eddie
dereknkathy 04-26-2012 05:35 AM
can someone verify this? my 1-piece flywheels don't seem to have any counterweight on-in them.
BillK 04-26-2012 05:45 AM
dk,
I bet if you look at it closely you will see a weight molded into the flywheel.
However, there is the possibility that if it is a custom built engine that it is completely internal balance with no weight on the flywheel.
Chris32900 09-08-2018 07:11 PM
Flywheel marine vs automotive
Trying to figure out if i can use the standard or manual flywheel or the automatic flywheel seems to be to thin compared to the old one i took out which is a 12inch version an it was a 82 350 an im replacing motor with a 97 350
Chris32900 09-08-2018 08:35 PM
Help
any help please
BUP 09-09-2018 12:10 PM
no
Chris32900 09-21-2018 11:06 AM
Originally Posted by BUP (Post 4648245)
no
yes
