-   -   Anyone know how to remove hydraulic stud on k-plane (https://www.offshoreonly.com/forums/general-q/274322-anyone-know-how-remove-hydraulic-stud-k-plane.html)
FBRONCO 04-12-2012 01:13 PM
I think I need to replace my upper k-plane mounting plate due to some corrosion in the hole for the indicator cable. Does anyone know how to remove the thru-hull hydraulic studs so I can re-use them? Anyone know where I can get the upper plate for the least amount of money?
FBRONCO 04-12-2012 08:13 PM
Anyone?
Griff 04-12-2012 11:30 PM
Might be cheaper to just hace the corrosion ground out and then weld in the damaged area and have it redrilled.
c_deezy 04-12-2012 11:53 PM
They should just screw out from the boat side of the plate. Just take off the plastic nut on the outside, then turn them out. May need a pipe wrench.
There were some k-plane plates in the swap shop for a decent price.
sac 04-13-2012 01:47 AM
Snap-on makes a collet type stud puller, they work excellent.
