-   -   Specs for a 88-91 7.4l Bravo? (https://www.offshoreonly.com/forums/general-q/274371-specs-88-91-7-4l-bravo.html)
carreraboy1 04-13-2012 01:47 PM
I'm trying to figure out the specs for the block that is in my active thunder. The flame arrestor cover was for a 454 mag motor. When I looked up the serial number on the block the results were for the 88-91 7.4l bravo. Does anyone know if this is a mag motor? Also where can I find the specs for it as far as rpm range and HP?
dereknkathy 04-13-2012 04:36 PM
post the serial number on here. there are guys here who will tell you for sure right off. look at intake manifold though. is it a high rise with large looking runners? or is the carb flange way down between the mating surfaces to the heads with smallish looking runners? the main diff is internal- steel crank, better rods, forged pistons, rect port heads, more cam. but the most obvious diff is the intake manifold.
carreraboy1 04-13-2012 04:48 PM
Serial number is 0c754611. It does not have a high rise intake so in thinking it is not a mag but if anyone has any input as far as the specs for this serial number it would be greatly appreciated
