help with 383 chevy thunder 383 vortec
just purchased a 1988 donzi 227 with that engine in it. says it a one year old or so summitt gm crat engine. runs great but only turn 4700 4800 rpms thru a cobra outdive and 21 michigan 4 blade prop.speedo says 53mph....this seem low on both the rpm level and mph...has aftermarket exhaust manifolds thru transom 4" exhaust. i can't find a whole lot of infoonthis donzi model...supposedly a pretty rare model....but previous owner said boat weighs close to 4000 lbs.....any info on this engine? can't find much on summitt website or donzi's for that matter. shouldn't it turn 5200 to 5500 and at least reach to mid 60's?
If you can find a three blade OMC Viper 21p i think you and that stroker will be much happier . Dump the Michigan Wheel , your trying to get performance out of a stone .
I'm rebuilding one of those engines now for a friend who flattened lobes on the cam in an hr or two run time. His engine has:
18cc dish pistons kb hypers 64cc vortec heads cast rods and crank 9.5:1 compression The heads were modified to be able to take a .507 lift cam w/ 1.5 rockers His bore is actually 4.04 so its a 385 34* timing Supposed to be 400hp Make sure you are running good high zddp oil and/or additive to make the cam live. That is if yours is flat tappet too. |
Its a roller motor. With roller cam. Is 5200 or so rpm about right?
Originally Posted by allious
(Post 3664047)
Describe the carburetor, intake and exhaust. I agree...should be in the 5000~5500 RPM range at WOT. i am thinking a 3: blade 21" but the 19" will be a good start. Two tons with that horsepower/torque should put you at 60+ if it's dialed in properly.
Originally Posted by sprink58
(Post 3664100)
Might try posting this question on Donzi.org, theres a wealth of knowledge on all and rare Donzi's. I'm sure someone over there can tell ya what the boat should run with your power
fixx
is this the same style donzi as you have?
http://tampa.craigslist.org/psc/boa/2949436495.html if it is be glad your getting that kind of speed out of it..that boat has a wide beam for its size.. |
Originally Posted by mrfixxall
(Post 3664712)
| All times are GMT -5. The time now is 01:12 PM. |
