-   -   Running a thermostat (https://www.offshoreonly.com/forums/general-q/274478-running-thermostat.html)
BadBoy 04-15-2012 06:52 PM
How and is it important to run a thermostat? My boat is a 79' Scarab 300 with twin 330 hp bbc and TRS drives, I pull water in from the bottom of the boat, I guess it is considered an open system. I pulled the t stat housings off, the port engine had a stat, the starboard didn't, never heard of doing that, I've only owned the boat a couple years changing exhaust on the boat putting captains call on it trying to get it out of the
70's
seafordguy 04-15-2012 07:08 PM
I don't have any stats. I always do make sure though that I get the oil temp up enough to boil off any water.
dereknkathy 04-16-2012 05:30 AM
the problem with no t-stat. your block is too cool. it is designed to run at a certain temp. you will get rapid bore wear from too low an operating temp.
NightHawk 04-16-2012 05:52 AM
as well as poor fuel economy and condensation.
Redhook98 04-16-2012 06:08 AM
Run the thermostats. They are there for a reason.
BadBoy 04-16-2012 07:15 AM
OK, what temp do you need to run or do they only have one temp?
MILD THUNDER 04-16-2012 08:43 AM
Guys around here been running big power supercharged big blocks in boats for many years without water thermostats. The reason for it is a cool block and heads means less chance of detonating.
However, in a 330HP 454, there really isnt a reason not to run stats. If you dont have oil thermostats, then put the water thermostats in. 140* stat is fine.
silent lucidity 04-16-2012 09:17 AM
I think efi and mpi's run at 160...
MILD THUNDER 04-16-2012 09:19 AM
I doubt his 1979 30ft scarab with 330's has MPI or any kind of EFI. The OE merc stat for his engine is probably a 143* merc unit.
BadBoy 04-16-2012 01:22 PM
just q carbs no efi thanks guys. I have another ? I changed from the old log style exhaust manifolds to center rise, my thermostat housing is 2 parts, lower has outlet to the water pump (circulating pump) outlet to sea water pump 4 outlets to exhaust/riser, upper has 2 outlets to exhaust/riser.With center rise I only need 4 total. Is there a upper without outlets and still be able to run stat?
dereknkathy 04-17-2012 06:18 AM
buy later model t-stat housings. you can make the old ones work, but they are old and rusted up.
mike tkach 04-17-2012 07:36 AM
how do you know his are rusted up,have you seen them?
MILD THUNDER 04-17-2012 11:06 AM
Im not sure what you mean when you say you only need "4" total.
Normally, when upgrading to some performance manifolds, you only need one 1" water hose feeding the exhaust manifold. If you have a t-stat housing that has 2 outlets per manifold, like most factory mercruisers, they make a stainless Y fitting just for that purpose. This way you get water to the manifolds when the stat is closed.
BadBoy 04-17-2012 09:20 PM
( MILD THUNDER) My center rise manifolds have water fitting on the bottom of the manifold and water fitting on the riser and a small fitting on the riser that goes to the trans cooler (TRS drives), that makes 4 water connections to the exhaust per motor.
I have pics of my stat housing don't know how to put on here. What style stat housing do I need to use?
The old log style manifolds have water inlets/outlets at both ends of the manifolds and 1 on the riser, and a small 1 on the riser for the trans cooler. That makes 3 per manifold, 6 on the stat. 4 bellow the stat, 2 above the stat.
My center rise manifolds are mercruiser
