Aeromotive fuel pump
Any body using the red Aeromotive pump on blown EFi applications? Pressure was dropping off on the Dyno with the dyno's Red Aeromotive pump. Pressure starting dropping at 4500RPM and was critically dropping at 5500 RPM. Boost reference vacuum line was connected. Engine was making pretty big power at 5500 RPM
Irrespective of the condition of the dyno shop's red Aeromotive fuel pump and feed system I believe you should always run a marine engine on the dyno with the same fuel pump, filter and lines you will be using on the engine in the boat as the actual fuel mapping or jetting you will be doing on the engine and what you will want to end up with in the boat can change pretty radically with changes in fuel flow you may see going from the dyno's system to the system ultimately that will be feeding the engine in the boat.
Also remember that fuel pressure alone is not a measure of fuel flow volume, fuel flow is measured in gallons per hour not PSI. Engines burn volumes of fuels not pressures!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Another issue is voltage to the pump at any time during it's operation. I used the Weldon 2345 pump and filters that are installed in the boat. I also ran the alternator used in the boat. We never had a issue with the fuel system capacity, and I was able to monitor system voltage on the data logs.
So as well as the pump and plumbing, the voltage source and wiring to the pump is very important.
Hope that helps.
Dick
Hope that helps.
Dick
Eddie
that's kind of reassuring,as my setup runs best at barely 38-40 lbs (496/whipple)...still have to take O2 readings this spring...
Interesting topic.
I was assisting in mapping a blown 502 MPI that was equipped with an Aeromotive Red pump and a Kenne Bell regulator. I was surprised to see the pressure bleed off that fast when ignition was killed, feels like there could be problems with fuel in rails vapourizing. Anyone been there?
