-   -   How stiff is your MM steering?? (https://www.offshoreonly.com/forums/general-q/275021-how-stiff-your-mm-steering.html)
Flying Tomato 04-23-2012 03:14 AM
I have a Marine Machine full hyd, power steering set up with dual ext rams on a single bravo boat. (24 Python)
The steering seems too hard to me but I have never driven any other boat with the same type of steering set up.
It takes 2 hands to steer, no matter what the rpm, and idle speed is really tough. Lock to lock is about 3 full turns.
Need some input from others or maybe some tips.
Thanks in advance. FT
Mr Gadgets 04-23-2012 05:42 AM
Take a look at the helm and see what model it is. If it is a large capacity, it will make the steering hard. How many turns lock to lock is there? I had the same problem with my steering.. started out with about 1.5 LtoL and with a smaller helm ended up at 3 LtoL.. made life much easier..
Hope that helps.
Griff 04-23-2012 11:43 AM
I can spin my Marine Machine steering with 1 finger. Full hyd, twins and about 3 turns lock to lock.
Do you have a fluid reservoir besides whats in the PS pump?????
Flying Tomato 04-24-2012 08:49 AM
more info
Yes, I have an additional reservoir. Lock to lock is 3 full turns.
osur866 04-24-2012 11:29 PM
Does it have a filter? If so when was it changed last?
Flying Tomato 04-25-2012 03:29 AM
attemp #1
Ok, after doing some more reading on OSO----I will be checking the in-line filter and maybe removing it as a test. Maybe it is clogged or too restrictive.
I'll post results when done.
Thanks, FT
onesickpantera 04-25-2012 11:13 AM
I have MM full hydraulic dual ram and it's a little stiff at idle but not bad. Anything over 2000 rpm and it's smooth and easy.
