-   -   ECM identification (can i have de right ECM calibration checksum) Hitting rev limiter (https://www.offshoreonly.com/forums/general-q/275147-ecm-identification-can-i-have-de-right-ecm-calibration-checksum-hitting-rev-limiter.html)
Steph_rs 04-24-2012 07:13 PM
First:
Boat: Baja H2x 2001 (4 people + 1/2 tank) temp 7degree celcius
Drive: Bravo 1 , 1.50 gear ratio
Prop: Mirage plus 23p
Top speed on the rev-limiter (66-67Mph)
Engine is a 454 Magnum MPI 2000 (385hp)
RPM range: 4600-5000
Rev limiter (supose to be) : 5100-5150rpm
Last week end i have tested my new boat on the river, I try a WOT pass and a 4650-4750 i hitting the rev limiter. Is below 5100 alot, ok it is possible my RPM Gauge is off but 300-400 rpm it seem to be big.
I have a Mefi 3 Delphi 1623699 ECM , serial # 866999KA0005247 , Calibration Checksum: CB5A
Do you thing this is the right calibration (454 mag MPI)
Next time i'l try an other RPM gauge.
Any one have acces to mefi 3 ECM (454 mag MPI (385hp) and 454 MPI (310hp)) to check the part # and Checksum calibration # ?
Thank you for your help
Bajajack 04-24-2012 07:55 PM
my 2001 H2x with a 454 Mag (385 hp) has the same ECM as you do ,my tach was checked and reads 150-200 rpm low. Crockett marine raised the limiter during a reprogram
tunertech 04-24-2012 08:25 PM
what you have is the 16236999 MEFI 3 and the CAL ID is correct for your engine. Merc was the only user of the 999 MEFI 3 controller
Griff 04-24-2012 10:14 PM
I'm betting your tach/rpm gauge is off. Also, the 7*C/45*F temp will cause the engine to run 100-200rpms faster than it would in normal 30*C/85*F boating weather.
Steph_rs 04-25-2012 06:21 AM
Thanks guys, next time i will try the boat whit a different Tach (livorsi or something like that at higher exterior temps.
And if i hit the rev limiter again, i will try a mirage + 25p.
Thank you :)
