-   -   454 ProCharger piston holes (https://www.offshoreonly.com/forums/general-q/27526-454-procharger-piston-holes.html)
sgrady 06-28-2002 12:25 PM
What size jets ? Did you do a WFO Plug Check ?
Nordicflame 06-28-2002 02:34 PM
Sven,
I have a question also. I'm assuming your refering to a Lambda O2 sensor which would be a wide band type.
What are you refering to when you say it was .8?
An O2 reading on a supercharged motor should range (approximately) from mid 13's at idle and high 11's at WOT.
Dave
:confused:
