-   -   Remote filter bracket NPT size (https://www.offshoreonly.com/forums/general-q/275737-remote-filter-bracket-npt-size.html)
redstinger 05-03-2012 01:14 PM
My 89 Merc remote oil filter has a brass allen plug that I want to remove and mount an oil temp sender. Anyone know what size NPT sender I need for the thread of this hole?
dereknkathy 05-03-2012 04:39 PM
take plug to lowes and go up plumbing aisle. while there you might want to get an adaptor to 1/8th pipe. it is probably 1/4 pipe.
hallj 05-03-2012 05:36 PM
Mine is an 88 and is 3/8 pipe.
Jeff
Rookie 05-03-2012 10:39 PM
3/8NPT and do not get an adapter. Get the right size sender. If you add adapters it will set the sender back and not in the flow of the oil.
