Garmin 4208 Output for GPS Speedometer?
Is the Garmin 4208 capable of providing a signal to the GPS speedometer head on the dash, so I can only have one antenna for the chartplotter?
http://www8.garmin.com/manuals/3111_OwnersManual.pdf
You have a NMEA 0183 output. So, you should be able to connect the speedo. You might have to buy some type of harness. |
Originally Posted by Dave M
(Post 3682568)
100% correct - use the blue wire. Works just fine |
| All times are GMT -5. The time now is 04:23 PM. |
