496 problem
I am not losing coolant from the closed cooling system and yes I went back with the stock 496 exhaust I even pressure tested it before I put it on so I guess my next step is pull the cooler and pressure test it.
Originally Posted by jab052783
(Post 3685041)
Regardless, change the oil and run it up to temp for long as possible and watch it. Run it with oil fill cap off. |
496 problem
Ok I have pressure tested both closed cooling systems and found a small leak on one heat exchanger I had it fixed and pressure tested both engines over night and both never lost pressure or any fluid. I also pressure tested both oil coolers with them out of the boat over night on full water hose pressure with no leaks is there some way that the water could of came through a pcv valve or the oil fill tube when I washed the engines before I put them back in the boat?
496 problem
bump
| All times are GMT -5. The time now is 02:08 AM. |
