-   -   Mercury Racing 600 SCI Fuel Consumption (https://www.offshoreonly.com/forums/general-q/276243-mercury-racing-600-sci-fuel-consumption.html)
FasterFaster 05-14-2012 09:29 AM
Rev CAUTION!
Originally Posted by Pash 1 (Post 3685422)
I guessed that it would top out @ 6000RPM as that is the rev limited fitted
Watch your valve train like a hawk! Mercury never intended these engines to run 6,000 rpm. If they're stock 600SCi heads, they were rated at 5,200 max. At 6,000 you will frequently replace rockers, springs and valves -- if you are lucky. Pistons, rods, cranks and cylinder blocks are likely, if your engine swallows a valve.
http://mercuryracing.com/sterndrives/hp600sci/specs.php
Griff 05-14-2012 11:14 AM
Originally Posted by Pash 1 (Post 3685006)
Hi,
Can you help me out on this, I have a pair of Mercury Racing 600 SCI's producing 750BHP each what fuel consumption should I expect to get at full revs of say 6,000 rpm, The boat is a deep "V" and weighs in at 6000Kg
thanks
Martin
Your HP divides by 12 will give you a good estimate. 750hp/12=62.5 gallons per hour at WOT. That is per engine.
relaxalot 05-14-2012 11:43 AM
I have a single 600 sci stage 2 whipple. I am very happy with it and have had it for two years. I guess I should say happy except for fuel consumption. I don't have a formula but here is a good one. Keep your wallet handy!
Kelly O 05-14-2012 11:48 AM
VERY accurate, according to Smartcraft on my 600sci's with Whipple Stage 2 upgrades.
Have heard of issues spinning stock valvetrain too high, so re-geared to keep just above the stock 5400 limit. The last 25 or so hp achieved by the extra rpm is not worth the loss in reliability.
Whipple Charged 05-14-2012 08:49 PM
Rev limit is 5850, 400 more than stock. I'm not sure you have to watch it like a hawk, that seems a bit extreme. They should be inspected more regularly than stock, but by no means all the time.
Pash 1 05-19-2012 03:32 PM
Thanks Guys very Handy information...
