-   -   Scorpion Roller Rockers (https://www.offshoreonly.com/forums/general-q/276564-scorpion-roller-rockers.html)
hadleycat 05-16-2012 05:02 AM
Thinkin about puttin the Scorpion Roller Rockers on my Gen V 454 mag. Anyone done this. Any performance gains? Any problems
Rookie 05-16-2012 08:18 AM
I have run scorpions for the last 10yrs. You will not see any performance gains just adding roller rockers. Save your money. The new scorpion HD marine version is what I believe Mercury Marine is using on their new builds.
hadleycat 05-16-2012 09:55 AM
Thanks, I really should wait till the end of the season and do a bigger cam and rockers at the same time. Its getting too close to summer to pull my engine and do the cam right now. Thought I might gain a little by doing the rockers right now. I have the itch to tinker with my boat. It never seems to go away.
bcfountain 05-16-2012 11:59 AM
the biggest gain w/rollerrockers is not h/p gain but the lack of friction.w/rollerrockers there is less friction.less friction,less heat.less heat=happer motor and lower oil temps.
matthewr 05-16-2012 03:57 PM
Im not 100% but I think the Gen 5 and 6 rocker arm studs are not setup for adjustable rockers. Someone please correct me if im wrong.
http://www.cpperformance.com/c-367-r...sion-kits.aspx
hadleycat 05-16-2012 07:32 PM
I believe you are right, you have to buy the adapter kit 3/8 to 7/16
mike tkach 05-16-2012 08:00 PM
when you do take the engines out,have the 3/8 holes drilled&taped to 7/16 threads,then you can use rocker studs for mark 4 heads,much stronger imo.
hadleycat 05-16-2012 10:05 PM
Thanks for all the advice gentleman, Right now i am finishing up some custom pipes to route my 496 manifolds and risers to my 454 mag. thru transom tips . Hope to have it on the water by this saturday. Turns out the 496 manifolds and risers are 1 3/4" taller than the cast iron 454 manifolds and risers. Fabricated an "S" pipe from aluminum to allow them to mate up properly.
